how can i include a vi to help me save all the measurement from 10 to 100000
hi, how can i include a vi that will store my data or save  them for each of the step increament , from the starting measurment 10hz to 10000000hz to the last. pls help
good
(2,166 Views)
Hi ifyo,
I couldn't run your VI as i dont have all the components of it. But i have attached herewith a vi which will show you how to save continuously acquired data into a text file. The explanations are added on the block digaram. Let me know if this doesn't help and you need more information.
Nitzz
(Give Kudos to good Answers, Mark it as a Solution if your problem is Solved;))
(2,158 Views)
