how can i link 16 bit assembly programs(8086 assembly) to LabVIEW ?
how can i link assembly programs to LabVIEW programs?
if it's possible to link assembly to LabVIEW then how can i assign memory addresses to LabVIEW variables?
for example how can i assign 300 hex of system RAM to a byte variable in LabVIEW?
and finally the format of program must be com,exe or asm to link to LabVIEW?
(3,002 Views)
You will need a file from ni.com called accessHW.zip
You may also need to compile your assembly into a win32 dll and then use the
Call Library Function in LV.
Mike Sachs
Intelligent Systems
"Biomedical" wrote in message
news:506500000008000000EB4F0000-1023576873000@exchange.ni.com...
> in LabVIEW?
> LabVIEW?
(3,002 Views)
