how can i log two (almost equal) data streams into one spreadsheet file?
My problem is (as stated above) that i would like to log data obtained from 15 current-sensors and data obtained from 15 pressure sensors into one spreadsheet file. The idea is to put them next to eachother (preferabley pressure current sensors 1, pressure current sensors 2, pressure current sensors 3 etc.).
Next to that I'm having difficulty logging certain constraints into a separate spreadsheet file. I.e. I've placed a maximum value constraint on my datalogger and I wish to log the data that has surpassed the max. constraint seperatly from the main logging file (see above) and (of course) preferably with the associated sensors. I would be extremly grateful if someone
out there could help me with this problem becouse when I've fixed these problems my internship will finally have come to an end (and i NEED a vacation). Thanks in advace;
Gideon Haan
Nefit Buderus bv Deventer (Netherlands)
gidefonz@gmx.net
(2,528 Views)
Shouldn't be too difficult. You would obviously have to have some form of test to see when your data has gone out of the specified range. You could then have this secondary logging process inside a case structure. You could innitialize this second file with the same header info. This is easiest if you go ahead and log all the sensor values into this new "surpassed" file if any of them are over. Otherwise, you will have to enter space characters ahead of the sensor values to ensure that the columns line up. You can create a string constant with a bunch of space characters and just use it over and over as necessary.
(2,528 Views)
