how can i make a condotion using a string?
can I use the string as a condition?
Thenk You
(3,010 Views)
yes you can as an input to a case structure or as inputs into the conditional functions such as an equals function. These functions are polymorphic and will allow you to connect various data types and compare them.
BJD1613
Lead Test Tools Development Engineer
Philips Respironics
Certified LV Architect / Instructor
(3,010 Views)
If you mean for a case structure, then the answer is yes as of something
like LV5.1 or LV6. You enter in the strings with quotes and comma
separated. I suspect there is an example of this. If this isn't
powerful enough because you want wildcarding and such, use Match Pattern
or other code in front of the case and output an integer or enum.
Greg McKaskle
(3,010 Views)
