how can i make a graph y is unmber pasing from UDP port,x is the time stamp.and in the same time this graph can display several numbers to compare.
y is number(the blue wire)pasing from UDP port,
plus in the same time this graph can display several differenr numbers to compare.
(2,442 Views)
