how can i make a signal read from sound file i have---urgent
i built the a loop with sound file and i am trying to make a graph or chart read the signal from the sound. how can i connect them together and if someone have any ixample. will be nice
thx
(2,674 Views)
Specifically, what sound function are you using? The ones that read a file have a 'data' output that you wire directly to a graph.
What kind of example do you need that is not there with the many examples that come with LabVIEW? Perhaps you should attach your code.
(2,663 Views)
i am playing a .wav file and it just want to know how to connect graph or chart .
like what u get sometime from microsoft media when u play sound file, u see cool signal moving and changing depend on the sound
(2,657 Views)
You already said you were playing a wave file. I told you how to connect the built-in sound functions to a graph. I asked you what function you were using. I asked you to look at the examples. I asked you to post your code.
You said it was urgent, but you don't seem inclined to listen to what I've said.
(2,652 Views)
