how can i make an usrp kit noise generator (or jammer) using LabVIEW 2011?
Hey,
I have a spectrum sensing NI USRP/LabVIEW kit and want to jam the signal that received by first USRP by using another USRP.
Any solutions for that?
(3,234 Views)
Have you checked out the USRP examples (check out the examples folder under the NI-USRP entry in the start menu)?  This may give you a better idea of where to start or at least help narrow down your question a bit.  If you can provide some more specifics of your application it would be easier to determine if there is a similar solution that you may be able to start with.
James K.
(3,201 Views)
