how can i movie piezo module from 0 to 80µm in 80steps with one click. i.e piezo system should move 0 to 80µm automatically and stop with one push button.
hello,
can anyone help me with this issue i would like to move piezo from 0 to 80µm in 80steps with one click? i able to move manually by changing the values but it needs to be done automatically with one button.
thanking you in advance.
Message 1 of 8
(2,795 Views)
Accepted by topic author RAJ1708
Hi Raj,
you need a loop, set to iterate 80 times. Send a command for a step in each iteration...
Message 2 of 8
(2,783 Views)
Hai GerdW
i want to create start and end positions i.e i would be able to change the values as required for example if I say start position as 10µm and end Position as 30µm and should happen in that way for any number.
present I  used a numeric indicator with that I can only change value. can u help me with this what commands should i use. if possiböe can u please attach example VI how to create start and end commands.
i attached Vi image u can look at once.
thanking you.
Message 3 of 8
(2,758 Views)
Hai
I want to create start and end positions i.e I would be able to change the values as required.  example- if I say start position as 10µm and end Position as 30µm and should happen in that way for any number.
I used a numeric indicator with that I can only change value. can u help me with which commands I can control start and positions of the device.
if possible can u please attach example VI how to create start and end commands.
I attached Vi image u can look at that.
thanking you.
Message 4 of 8
(2,793 Views)
You attached "invisible VI Image".  Attach no Image, attach a VI (please).
Bob Schor
Message 5 of 8
(2,762 Views)
i attached can u look over it
Message 6 of 8
(2,761 Views)
You say you used an indicator, but your picture has a control circled.  If you would like to limit the range of values accepted for the control, right-click on the control and go to Properties.  There should be a Data Entry tab which will allow you to define the value limits of the control and how to respond to values outside those limits.
Also, please don't post pictures of code.   Post the actual VI.   Pictures are often (usually) not descriptive enough for anyone to be able to help you.
Message 7 of 8
(2,754 Views)
And please don't create multiple threads on the very same topic!
Message 8 of 8
(2,741 Views)
