how can i reset the windows CE password running in TPC?
am trying to configure ftp on TPC2006 running under Windows CE ,it ask me to enter the user name and password. as written in the datasheet the initial user name is ADMIN and no password required , but it dosnt work so how can i fix this problem? are there any way to reset the password?or are  there a default password?
(3,810 Views)
Howdy,
After checking into this issue, I've found that there is no way to reset the password on the machine in software.  You'll have to re-image the Compact Flash card that the TCP uses for boot up.  The Improved Display Driver for TPC-2006 Industrial Touch Panel Computer will walk you through the steps to image the CF card.  If you have any other questions about setting up an FTP server on the TCP, please refer to the How Do I Configure the FTP Server on the TPC-2006/2012? KB.  I hope this works out for you!
Sincerely,
Chris G in AE
(3,795 Views)
