how can i run my fm modulation on LabVIEW PDA Module ?
Hi All,
        Anyone can tell me that how can i run my FM modulation on PDA devices which is using by LabVIEW PDA Module? Actually I build one tab control and i put all the waveforms and sliding controls on the tab control. By running on LabVIEW its show correct waveforms but when i use NI LabVIEW PDA Module and create PDA project, after that i transfer to my PDA devices by using Microsoft Active sinc, it does not show properly on my PDA devices and the wave forms running also not correct. So any one can suggest me how can i solve this problem?My primary target is to run my FM and AM modulations on my PDA devices.
Thanks a lot for your help
Best Regards
Nyan Lin
(2,756 Views)
Hi Nyan,
Please see my response to your other post
Jennifer R.
(2,729 Views)
