how can i simulate boost converter using labview 7.1?
respected sir/madam
                                        i am karthic i am doing ME degree in coimbatore. i am doing project labview based boost converter analysis. i want to know how shall i simulate this booct converter in labview 7.1. i am trying in fornula node also is  any solution for simulating this boost converter?. kindly i requesting you to give me a idea to simulate this boost conveter circuit.
thanking you
yours truly,
karthic.m
(3,360 Views)
Hello Karthic,
While I have not seen any LabVIEW modules created to simulate a boost converter, I do know that it is possible for LabVIEW to interface with Multisim. Essentially you can create the schematic for the boost simulator in Multisim and import a LabVIEW VI into the Multisim environment. Aside from this suggestion, I do not know of another way to build this simulator without characterizing the system and building the simulator on your own. I hope this information is useful for you. Please post back with your solution. Thank you,
Mike D.
(3,341 Views)
