how can i store a motor value to be last value before it stops
I'am attaching one VI . In this VI i'am using a motor such that when I give a string like +500\r\nZ the motor will rotate 500 steps and reads 500, When I switch it off it reads zero to avaoid it what I have to do. I need the read value to be the last value when the motor is on. Can YOu please help me.
(2,555 Views)
Asking same question at different place doesnt solve problem fast. See my last VI uploaded in your last question.
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(2,550 Views)
it will not solv ethe problem
(2,525 Views)
Stating directly - 'it will not solv ethe problem'. doesnt solve problem.
Tell me what is the requirement or in the last VI what else you need ?
That may solve the problem
--Ranjeet
(2,512 Views)
