how can i synchronize analog output and analog input timings to generate and measure voltage at the same time.
(2,999 Views)
Take a look at the DAQmx Trigger vi. and/or search the example finder for 'trigger'.
"There is a God shaped vacuum in the heart of every man which cannot be filled by any created thing, but only by God, the Creator, made known through Jesus." - Blaise Pascal
(2,990 Views)
Thanks, i am new to labview. It would be really nice if you could give some more idea as to how trigger vi will help in synchronizing the timings between analog output and analog input voltage.
(2,977 Views)
Read this Tutorial
http://zone.ni.com/devzone/cda/tut/p/id/3615#toc3
And also refer to this link where You have repeated this question.
PS: Please stick to one thread. That way, its easier to keep track of your query and answers
(2,970 Views)
