how can i update the spreadsheet in front panel
Hi all,
I need to update the datas read from excel sheet in labview front panel in same format( as a spreadsheet).  I placed the spreadsheet in front panel from activeX object. but i could not insert the data inside it. Because the read data from spread sheet is 2D string array but the spreadsheet in block diagram is refnum indicator. what should  i do to place the data in Spreadsheet in labview front panel.
Thanks in advance.
(2,699 Views)
Hi ragupathi,
you have to use property and method nodes to work with the ActiveX control.
Mike
(2,687 Views)
http://forums.ni.com/ni/board/message?board.id=170&message.id=26319&requireLogin=False
.......^___________________^
....../ '---_BOT ____________ ]
...../_==O;;;;;;;;_______.:/
.....),---.(_(____)/.....
...//____//......
..//____//......
.//____//......
(2,664 Views)
