how can we call the vi on client in running condition from server
i have call the vi front pannel on client from server.its not in running condition.i want that when i call vi front pannal on client from server (through remote client connections) it should be in running condition.please make a help in this regard.i have try through option that when vi open it would in running condition but that work for local pc but not for remote pannel.
thx
(2,998 Views)
Could not quite undersand your query
culd you plz rephrase and tell what exactly is the problem??
(2,992 Views)
It sounds like you are trying to use VI server to programmatically run a VI over the network.  Although I am not sure exactly where you are getting stuck, you should definitely make sure you have configured your server side permissions by seeing Tools -> Options... in LabVIEW, and configuring the VI Server Configuration, TCP/IP Access, and Exported VIs sections.  In particular, you'll want to enable TCP/IP in the Configuration page (along with a port number), then allow access to the set of IP addresses you want to allow access to your VI in the TCP/IP Access page, and finally make sure to allow access to your VI by adding in the Exported VIs page.
I hope this helps!
Best Regards,
JLS
Best,
JLS
Sixclear
(2,981 Views)
i have call the front pannel on client from server  through connect to remote pannel dialogue box.FP is called succesfully but now my problem is this that i want that when i call the fron pannel  on client it should be call in such a way that it is in executable form(in running condition).i have try different option but can not do it succesfully.so please guide me that how can i call vi front pannel on client while it is in running condition.THX
(2,968 Views)
A VI on the server should always be running. You can go to VI Properties>Execution and check the Run When Opened box. You should also make it impossible for a client to stop the VI or close it.
(2,957 Views)
