how can we get the image which is stored in clipboard by labview, is there any functions available like text from clip board
How can we get the image which is stored in clipboard by labview, i can get the text in clipboard by using invoke node directly.but i cannot get the image, is there any functions or vi available.(image is in Png format)
(2,683 Views)
The Read from Clipboard method is, unfortunately, limited to text. If the clipboard contains an image then you need to use OS-specific functions calls. This is an example program for Windows. It's old, but it should still work.
(2,663 Views)
Oh Thank you very much...
(2,643 Views)
