how can we use proprty of blinking in picture ring control in labview 7.1
Hi
sir i have three pictures in picture ring ctrl..i have to change picture according to certain conditions in my program..Now i want that when my first picture will be displayed on screen,then it should be in blinking/flickring condition..Similarly i can stop its blinking when required..how can i do this?
By using Blinking property(property node) of ring ctrl,i m unable to show it...can u help me regaring that....(Labview 7.1)?
thanks
(2,848 Views)
Have you been able to use this property node into a very simple example in LabVIEW 7? like a blinking LED?
(2,818 Views)
yes i used the blinking property in LED..its working but i have to use the picture ring cntrl having some shapes of icons...if i set teh VALUE 0 or 1 to ring cntrl and then i set blinking true,its not working...In LED we set two colors which blinks,how can we do here...plz guide me
thanks
(2,797 Views)
Could you post an image of you code to try to visualize what you're doing?
(2,774 Views)
