how concatenate date and array to write in excel?
Hello
I have a problem to concatenate a date array and numeric array. can you help me?
I want save Measurement of a sensor with save time in an excel (row 1 column1 save date and row 1 coulmn : save sensor data). but I cant save these two value seperatly(my clocks cant do it). now, I want concatenate them at first and then save them. is it possible?
Best Regards
(3,587 Views)
Accepted by topic author behzad1
Try the attached.  You'll understand it as soon as you see it.  If not, shout.
(3,560 Views)
thank you Zwired1
your respons, really helped me.
just a problem is that, when I save data in the excel file, and read that a agein,  my date change to unkown number. for example: 11/10/2014 change to 41953! in labview. do you know why this happen?
Best regards
(3,531 Views)
Hi benzah1,
Attach your vi. It will be more helpful to solve the problem.
(3,525 Views)
The date showing as a number is an Excel display format problem.
41953 is the Excel number representing 10 Nov 2014.
In Excel you need to....
Select the cells containing the date
Format -> Cells -> Number -> Date
 EDIT: This fix changes how the date looks when displayed in Excel. I am now not sure if your problem was when you display the result in Excel or after reading the Excel file back into LabVIEW.
Rod
(3,519 Views)
Thank you Rod
in excel, show correct date. my problem is when I display the result in labview again.
Hello Vij@y
which code is need? i just read a date saved in excel. and format is problem.
Best Regards
(3,475 Views)
Hi Behzad1,
Attach the excel file and the code (after reading the Excel file back into LabVIEW).
(3,461 Views)
