how concrete two diffrent type data for writing to Excel file?
hello
I want concrete two diffrent type data for writing to Excel file. how can i do it?
actually, I want save numeric data, like level of reservoir in 24 hours along with it's date. example:
                            1           2            3              4
24/10/2014        50        70          49          49
type of date and levels are different. in addition, Excel should be support this combination in the same time.
is there any idea?
Best Regards.
(3,197 Views)
Your best bet is to save to text file like the attached.
When prompted, save the file as somename.csv.  Double click the resulting file and Excel should open it as you need.
(3,185 Views)
tnx Zwired1
my data in labview are Independent from text or excel. do u know how can I concrete them at first?
(3,166 Views)
Concrete - http://en.m.wikipedia.org/wiki/Concrete
Do you mean concatenate? For an array, you must use a common data type. Convert the numerics to strings and build the array with the date/time strings.
(3,142 Views)
Time to Exell can be found here
BUT, in your case I would use a *.tdms file
(3,128 Views)
