how create a html report with four graphs?
Hi
I need make a html report in labview 8.2, and I am trying the example:  Example HTML Report.vi , but there is only graph in the example´s report. Is it possible use this example and make a report including 04 graphs?
thanks
bramatti
(3,481 Views)
Hi bramatti,
yes it is possible. If you call the two vi´s "strip chart" and "Append Control Image to Report" directly one after another, then you can input this combination as often as you need, in your case 4 times.
Mike
(3,478 Views)
Thanks, Mike, you are right....
but...only another question....the graphs stay side by side in the report in the horizontal....how can I print the graphs one above the another....in the vertical way?
(3,468 Views)
Hi bramatti,
insert the "New Report Line.vi" after writing one graph.
Mike
(3,459 Views)
Hi Mike
....Ok!!!.....thanks a lot
Bramatti
(3,448 Views)
