how create multithreading dynamically?
Hi,Baji
Thanks for you reply first.I understand your mean.Yes,nothing  is happening in parallel,but my main vi invokes the process vi in a short time.Even there is a gloss that they are processed in parallel.So invoking vi dynamically and running the vi in mode 'not until done' will create a thread,yes?
Message 11 of 12
(806 Views)
Experiment this by putting just a 1sec delay in the process VI run the code with 4*4 array. check the programme time, if it takes 4 sec then nothing is happening parallel.
Balaji PK (CLA)
Ever tried. Ever failed. No matter. Try again. Fail again. Fail better
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved.
Message 12 of 12
(803 Views)
