how delete the special rows of array string
@Oligarlicky wrote:
I guess marii will have to...
If you want to be a lot more memory efficient, it gets even more fun.  Keep the array in a shift register.  Also keep track of how many items you have found to keep in a shift register.  When you find an item to keep, you move it with Replace Array Subset (hence why we are keeping that count) and increment the count.  In the end, use Array Subset to get just the portion that you are to keep.  This keeps a lot of memory reallocations from happening.
Message 11 of 11
(505 Views)
