how do I break a for loop (inside) and a while loop (outside) at the same time by a control button
I have a while loop (outside) and a for loop (inside) and a control button within the for loop.  I want to stop the program by click the botton without finishing the for loop.  How can I do that?
Thank you in advance.
(3,377 Views)
I have found the answer, probably one answer.  This works, see attachment.  The iner loop will run from 0 to 9 continously.  The whole program will stop immidiately after the 'Stop' button is clicked regardless what 'index' is.
(3,372 Views)
HI Please find attached snapshot Regards, Santosh
Message Edited by SanRac on 12-17-2009 05:12 AM
Message Edited by SanRac on 12-17-2009 05:13 AM
(3,357 Views)
Hi SanRac,
Thank you for the help.  I use LabVIEW8.2, the break is not available to for loop.
Thank you all the same.
Qing
(3,350 Views)
i didnt see any for loop inside the while loop... any how it is possible to brake (stop) a "for loop" also.. Right click on the "for loop" and select the option "conditional Terminal" and wire a approriarte value to the  "loop condition" terminal
Regards
Guru (CLA)
(3,348 Views)
Here's a method that allows you to break (nearly) immediately upon hitting the Stop button.  No need to wait for the timer to complete.
CCT Snippet
Jim
(3,324 Views)
sorry, wrong topic.
Message Edited by Broken Arrow on 12-17-2009 07:11 AM
Richard
(3,310 Views)
