how do I change the font, size and format of tab labels?
How do I change the font, font size, and format of a tab label?  Can I replace the text label with a gif image?
(5,263 Views)
you can change the font,size,ect by going to the windowthat says text settings it is a list box right next to the pause button
Message Edited by Harold Timmis on 03-29-2010 02:29 PM
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
(5,262 Views)
I tried that, but it changes the font for the entire tabbed pane.  How can I change the font for just the tab label and not everything below it?
(5,255 Views)
this may help you:
http://forums.ni.com/ni/board/message?board.id=170&message.id=433950&query.id=820856#M433950
Harold Timmis
htimmis@fit.edu
Orlando,Fl
(5,247 Views)
Double-click on the tab name's text and then change it using the Font menu in the LabVIEW toolbar.
(5,246 Views)
Double clicking on the tab sends me to the block diagram.  Not sure how I change the font like that.
How can I also change the text in the tab label?
(5,241 Views)
I didn't say double-click on the tab. I said double-click on the tab selector's text. You need to use the "hand" tool if you have "Lock automatic tool selection" off in your LabVIEW options.
(5,231 Views)
