how do I count 0's and 1's
After converting boolean true/false to (0,1) I'd like to count the number of ones during data acquisition or if better the number of trues before the conversion. Everything I tried accepted a different type of data (string or waveform instead of word)
(3,231 Views)
How about feed the boolean to a case loop selector and set a counter in the loop?
(3,231 Views)
Bernd R.;
An option can be to create an array with the boolean results, convert the whole array into 0's and 1's and then sum the array.
See the attached VI.
Regards;
Enrique Vargas
www.vartortech.com
(3,231 Views)
Thank you Enrique, that works good. Just that I need to know the count with every consecutive, incoming value, not after the loop is finished. So a count in real time.
Bernd
(3,231 Views)
Well, you could use the Add Array Elements primitive on the Numeric
palette on the array of 0 and 1.
Rolf K
(3,231 Views)
OK, see if the attach VI is of help.
www.vartortech.com
(3,231 Views)
