how do I design a VI to show the voltage falling across a CR circuit?
I am trying to design a VI that can be used to show how the voltage fallls across a  resistor in a simple CR circuit when excited by a step input function. I have been trying to build each waveform separately first to see how they perform and then  merge them together using an XY Graph. For the Voltage across the CR circuit I am using an exponential function but I do not know how to design the VI so that Tau is divided by the Resistance (500 ohms) and the Capacitance (20 microfarads) over a time period of 50 milliseconds. Any help would be appreciated!
Kadeel
(2,625 Views)
