how do I disable one item in a radio buttons control at run time
I need to disable one item in a radio buttons control. At design time this is possible, but how do I do this at run time? Is this possible? I cannot find a property per item
(2,834 Views)
Use the property "Controls[ ]" - this gives you an array with references of each single button in the radio buttons control. These you can access with property nodes too.
Hope this helps.
Using LV8.0
Don't be afraid to rate a good answer... 😉
(2,834 Views)
OK, I found it. Thanks!
(2,827 Views)
