how do I install support for labview 2012 sp1 64 bit
I downloaded and installed Labview 2012 sp1 64 bit and
the installation is asking for a support disk.
Where can I download a support dvd for 64 bit Labview?
thanks,
desiko
Message 1 of 8
(3,821 Views)
Are you refering to the Device Driver Disc?  It's the same one as for LV 2012 SP1 32-bit.  Actually, all you will be doing is installing the same drivers as the drivers installed depends on the operating system, not whether or not LV is 32 bit or 64 bit.
Bill
CLD
(Mid-Level minion.)
Message 2 of 8
(3,814 Views)
Hi, Bill
Thanks for the fast response!
Yes, I am referring to the device driver disc.
Let me give you a little more information.
I installed LV 2012 sp1 64 bit side by side with LV 2012 sp1 32 bit.
The 64 bit installer asked for a dvd for support.  I cancelled out of that
part of the install.
Since I already had installed the device driver disc for LV 32 bit long
ago do I not need to do anything else to use LV 64 bit?
I needed LV 64 bit to use a third party VI library.
Thanks and best regards,
Darrell
Message 3 of 8
(3,809 Views)
Accepted by topic author desiko
You need to install the drivers again so that it will install the support for the 64-bit version of LabVIEW.
Message 4 of 8
(3,789 Views)
Thanks to Bill and Crossrulz!!!
Message 5 of 8
(3,779 Views)
Really?  I'm not doubting you; I just thought drivers were drivers and it would be the job of the software (in this case LabVIEW) to hook into them.
Bill
CLD
(Mid-Level minion.)
Message 6 of 8
(3,774 Views)
When you reinstall the drivers in this situation, the drivers are not going to be reinstalled.  What will be installed are those hooks for the previously not installed version of LabVIEW to use them.  The install will be really fast.
Message 7 of 8
(3,760 Views)
LOL it's a good thing I just followed the instructions and reloaded them anyway.  😉
Bill
CLD
(Mid-Level minion.)
Message 8 of 8
(3,743 Views)
