how do I retrieve a multicolumn cell value.
I'm filling a multicolumn list box for user selection from a dataset. I can return the selected row number, but the row number does not necessarily match the value of the cell that I need to query against.
Is there anything like an active cell text property?
(2,739 Views)
In LabVIEW you can use invoke node "Point to row Column". In the attached example, the string indocator shows the text of the element where a mouse-down happened.
Message Edited by altenbach on 02-01-2006 01:27 PM
(2,731 Views)
Thanx. That will do nicely.
(2,724 Views)
I forgot to mention that this is LabVIEW 8.0 only.
(2,717 Views)
