how do I start/stop a while loop programmatically inside a while loop
can somebody help?
how to start and stop a while loopprogrammatically, not just by clicking run button of the vi,
ex:- main vi has a while loop and it has a inner loop, main while loop runs until i stop, but the inner while loop should start and stop on a button press.
(7,466 Views)
This'll do it, but I'm curious about why you'd want to...
Jim
(7,458 Views)
thank you so much,
 I am trying to code the below picture
it should write 30 secs of data  every 8 hrs and this should repeat for 14 days.
see attached vi, im using 2 elapsed time vis to control this but if i use the 30sec timer inside inner while lt stops after 30 seconds and does not start whennext 8hrs elapse
so, i wanted to try to contol the inner loop, please see the elapsed timer.vi , any help would be much appreciated
(7,445 Views)
also, in the vi you sent, the outer loop seems to halt for the time the inner loop is running, is it possible to control only the inner one while the outer one still keeps running and stop wen i press main stop?
(7,442 Views)
No you can't have one loop running continuously inside of another loop that is also running continuously.  A structure can't complete its iteration until all structures inside of it have completed, which means the inner while loop has ended.  This is a basic understanding of dataflow withing LabVIEW.
Since you are new to LabVIEW, I would recommend looking at the online LabVIEW tutorials:
(7,433 Views)
This discussion was also started on LAVA.
Jim
(7,399 Views)
