how do I turn on multiple channels with a 9481
How do I turn on and off multiple channes on a 9481 relay module??? I am using a daqmx 9172 and am able to turn on and off a single channel with a signal generator  but am unable to do multiple channels with one daq assistant output.
Message 1 of 11
(3,839 Views)
You can add extra channels in your DAQ Assistant.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
Message 2 of 11
(3,836 Views)
Yes I did that by double clicking my daq assistant and adding another channel, clicked the run button and I can turn on and off the channels manually but when I go to run my program I can only get one channel to turn on and off
Message 3 of 11
(3,832 Views)
OK is it possible for you to post the code?
Adnan Zafar
Message 4 of 11
(3,830 Views)
How do I go about that??? Just copy and past
Message 5 of 11
(3,827 Views)
Hope you can open this
Message 6 of 11
(3,821 Views)
In your second DAQ Assistant you have only one line there. Like I suggested before, add channels in there by clicking on the '+' button right under Channel Settings.
Adnan Zafar
Message 7 of 11
(3,816 Views)
sorry wrong code
Message 8 of 11
(3,812 Views)
Create an indicator for your Convert from Dynamic Data node that is feeding into the DAQ Assistant. Do you see two booleans going on and off? I don't understand what your code is doing. Can you explain?
Adnan Zafar
Message 9 of 11
(3,809 Views)
I have two channels added but can only get one channel to activate
Message 10 of 11
(3,807 Views)
