how do I uninstall Labview 7 Express Evaluation?
We are still running Labvew 5.11 here as upgrading has been constatly deemed too costly by our management.
I wanted to view some sample code for LV 7 to help with a programing problem so I installed the evaluation disk we received a few years ago.
It installed but on reboot it comes up and says it is expired Smiley Mad
No uninstaller was provided, it does not show up in the Control Panel add/remove programs, and now all my vi's are associated to an expired Labview demo! Smiley MadSmiley MadSmiley Mad
Message Edited by RTSLVU on 10-12-2006 11:14 AM
=== Engineer Ambiguously ===
(2,598 Views)
Go Add/Remove Programs and select the listing for National Instruments Software. All NI software was moved to this instead of having a separate Add/Remove listing for each of the programs that get installed. Also, even if you don't uninstall, simply starting LabVIEW 5.11 and opening a VI should tell windows that this is the version of LabVIEW.exe that is current and should be used.
(2,590 Views)
