how do I use Real Time for cRIO 9012?
Hi, I have started to use cRIO 9012 and I have already connected cRIO 9012 with my personal computer, I launched the aplication"measurement and automation" (MAX) to check if I can see the device and I can do it. Now I want to use REAL TIME to work with cRIO 9012 I hope you can help me, greatings.
(2,929 Views)
Open a new project.
Select the target for which you want to develop the code.
Select the type of architecture you want to use.
There you go start the coding.
Is that what you need?
(2,921 Views)
Hi!!
Once you can see the device on MAX, you need to install all the software your application is going to need so it can run on the real-time controller.  After that, you can go on and develop your application using LabVIEW.  Here's a link to a very detailed guide for setting up the controller, creating a LabVIEW Project, selecting your programming mode (Scan Interface or FPGA), creating your VI, and finally deploy your application to your Real-Time target.
http://www.ni.com/pdf/manuals/372596b.pdf
Hope this helps!!
Anuar Rojas
Anuar R.
National Instruments México y Latinoamérica
Ingeniería de Aplicaciones
www.ni.com/soporte
(2,907 Views)
I have started to read the file, thank you!!!
(2,898 Views)
