how do I use "system execute" vi
I have one batch file named "linkdate.bat" which i was able to run and get response by command line, see attached file:"CMD.jpg"
well I tried to have LV to recall and run this batch file and to get a reponse in LV but I got fail when I did this way by "system execute.vi", see attached file: "System execute.jpg", the VI can run through but I got nothing reponsed. I donot know how can I have correct configure with "system execute.vi"
(2,846 Views)
Again, I attached the view of the result after RUN.
(2,843 Views)
Hi Neil Lan,
you should use the "cmd /c" command before your batch file name. See alse the examples about System Exec to get more information about it.
Mike
(2,837 Views)
