how do i convert unassigned long 32 bit integer data to double 64 bit real data
i current have data in unassigned long 32 bit integer format. however i need to be able to convert this data into 64 bit real data format in order to analyze the data. How does one go about doing this operation. thanks for your help
awoolf
(9,285 Views)
You want the 'convert to double' function:
Ton
Message Edited by TonP on 04-19-2008 11:32 PM
My LabVIEW Ideas
(9,276 Views)
I don't think his problem is quite that simple.
awoof,
Where did the binary data com from? Is it unscaled data from a DAQmx Read?
(9,262 Views)
