how do i create a VI?
I am new to Labview.  How do I create a VI?
Thanks for help
Message 1 of 8
(4,612 Views)
hi Trex600N
I hope you have installed labview. if not install it first. Then go to start>>National Instrument LabVIEW..
Then a window will get opend which will have title bar " Getting Started" .Click on "Blank VI"
here you go with new vi created. save it and progarm it.
Best of Luck
Gaurav Smiley Happy
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
Message 2 of 8
(4,606 Views)
I would recommend you learn more about LabVIEW from here. How to Learn LV
Message 3 of 8
(4,598 Views)
gak wrote:
hi Trex600N
Best of Luck
Gaurav Smiley Happy
LOL! I wish I could give more than one kudo! Too funny.
Message 4 of 8
(4,580 Views)
Thanks for reply.  I meant to create a sub VI .  I managed to learn how to create a sub VI last night.
Now, I would like to import a picture in to my front panel.  How do I do that?
I tried to import a picture .bmp but it did not work?  Any idea?
Thanks alot.
Message 5 of 8
(4,554 Views)
Have you checked the LabVIEW Help? It explains how to do this:
Import graphics for front panel backgrounds using either of the following ways:
  • Right-click the scrollbar of a pane and select Properties from the shortcut menu to display the Pane Properties dialog box. On the Appearance tab, use the Background, Browse, and Position options to set a pane background image.
  • Copy the graphic to the clipboard and paste it on the front panel. You also can select Edit»Import Picture to Clipboard and paste the graphic on the front panel.
Message 6 of 8
(4,551 Views)
what is funny ? i was trying to help.he dint mention that he wants to create  sub vi.
Gaurav k
Gaurav k
CLD Certified !!!!!
Message 7 of 8
(4,510 Views)
Were you able to apply the advice above? If you want to do this programmatically, see this KB http://digital.ni.com/public.nsf/allkb/BC9281DCFCBF7B5C862570120064362C?OpenDocument
Regards
Anna K.
Message 8 of 8
(4,480 Views)
