How about buffered acquisition? You can let your DAQCard acquire the number of samples you require instead of doing it with a FOR loop. Using a FOR loop means that you are software timed, which may as well be untimed since it's about as deterministic as the weather in Florida.
🙂Look for the "Acquire N Scans.vi" example.
If you want to do this the RIGHT way, use continuous acquisition. Start your acquisition and keep doing AI Read in a loop. Also include your porcessing and display functions in the loop. Just make sure your loop runs fast enough to keep up with your acquisition. At 250 Hz, you should have no problem.
Dan Press
www.primetest.com
