how do i export the vi documentation
How do i export the my project or vi documentation to microsoft word file?
thank you,
Ranjith
Message 1 of 9
(4,420 Views)
Hi Ranjith,
use a property node to read the vi documentation and use for example the report geration toolkit to write it to word. Do you know the code capture tool? Maybe this can also help.
Mike
Message 2 of 9
(4,419 Views)
Hi Mike,
I dont know about the Code capture tool. I have give documentation to all vis. now i need to put that into word document.
thank you,
rajni
Message 3 of 9
(4,410 Views)
Hi Mike,
thank you,
rajni
Message 4 of 9
(4,402 Views)
Hi Ranjith,
this is the link to the Code Capture Tool http://forums.lavag.org/Code-Capture-Tool-file121.html.
To get your documentation you can open a reference to all your vi´s. Use a property node to get your documentation. Do you have the report generation toolkit? If yes you can create the word document with it.
Mike
Message Edited by MikeS81 on 08-04-2008 03:00 PM
Message 5 of 9
(4,402 Views)
Hi Mike,
I installed the code capture tool. but it throughs error while running it.
what could be the problem?
Thank you,
Rajni
Message 6 of 9
(4,386 Views)
Hi Ranjith,
sorry, i don´t know, the Code Capture Tool was only a tip, i don´t know if it can help you. I know you can make good pictures from your code with it. Did you try it with the reference of the vi´s and the property node?
Mike
Message 7 of 9
(4,382 Views)
How big is your diagram?
That message indicates that you did not have enough memory to capture the image.
Ben
Message 8 of 9
(4,372 Views)
TRanjith,
Since you can print the documentation as RTF or HTML, pasting it into word will work. How many pages are created when you create the documentation?
Message 9 of 9
(4,369 Views)
