how do i extract/import time v/s signal data in excel and matlab
how do i import data from labview to matlab
(2,523 Views)
With Excel, you can poke values directly into spreadsheets using ActiveX, but often the easiest way is through a tab-delimited file. Nearly anything can read them and they are easy to generate in LV using the Array to Spreadsheet String function.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,523 Views)
