how do i get data from a website?
I am trying to access weather data such as visibility and rain from a website preferably BBC or MET office and display it on the frontpanel. I really don't have the first idea about how to go about it. I am making a programme to automatically open and close a telescope dome in undesirable weather and thought that this information from the net would make a great addition allowing the group that uses it to plan their viewing schedule without going online seperately but having it all right in front of them. Could anybody help me with this?
Message 1 of 21
(26,641 Views)
Hi Dan_,
you can use DataSocket to read the content of a website. Parse the result for the information you need. Another solution would be to use the ActiveX control and load the website there.
Mike
Message 2 of 21
(26,625 Views)
Here is a program I use to get local weather data off the web, it is an example of the Data Socket method Mike spoke about.  VI's are in LV8.0
Message 3 of 21
(26,621 Views)
If it's sufficient for you to simply display a web page directly, without extracting data from it, and you're on a Windows machine, ActiveX is definitely the simplest way to do it.  You can embed an Internet Explorer window in your front panel, let your LabVIEW code tell it what URL to load, and you're all set.  Take a look at the ActiveX Event Callback example, which is more complicated than you need but fairly simple and demonstrates an embedded Internet Explorer object.  You can also use IE to retrieve specific elements from a website and fill in a form, although that gets to be more complicated; see the Microsoft Developer Network (MSDN)  documentation.
Message 4 of 21
(26,612 Views)
Awesome_Larry escreveu:
Can you send the code for LabVIEW 7.0?
Message 5 of 21
(25,421 Views)
To save you some time, because not that many people have access to LV 8.0 and 7.1 anymore, the code to retrieve the HTML is very simple. You call Datasocket Read and in the URL input you feed "URL[text]" (for example "http://www.google.com[text]"). You also wire the URL to the second input, which determines the data type. This will cause the function to download the file at that URL and output it as a string.
___________________
Try to take over the world!
Message 6 of 21
(25,414 Views)
tst escreveu:
Thanks.
Message 7 of 21
(25,411 Views)
Does anyone know how to get a list of all store addresses from a retailer's website?  All of the information is in the Store Locator function but there is generally no easy way to get a full list.
Message 8 of 21
(24,485 Views)
Most likely that information is not on the website but in a database somewhere. Pressing the search button on the web page causes the server to run a database query and return the results to the webpage. Most likely you would need to run a series of queries to retrieve the information. For example test every possible ZIP code.
Lynn
Message 9 of 21
(24,477 Views)
Thanks - do you know if there is way to automate that? Or would I have to type it in each time?
Message 10 of 21
(24,471 Views)
