how do i get the database path from udl
Hi All.....
I would like to get the database path which is set in udl.
I tried with connectivity tools but all giving connection reference only.
Is there any way tp get the path of the database?
Thanks in advance
(3,290 Views)
A UDL is just a Unicode text file. If you read the UDL as a text file the path will be stored in the Data Source field.
(3,283 Views)
We use the Conn Get Properties.vi, from the Database connectivity tools
(3,280 Views)
HI
tHANKS 2 U BOTH 4 THE TIMEY HELP.
I used the get properties to get the database path.but the provider in4mation is not coming out after unbundling the cluster.
I am attaching a screen shot herewith.
Thanks once againm
(3,274 Views)
HI
When i unbundled by name...problem solved
thanx again
(3,251 Views)
