how do i make installer of minium Mb size having only one usb-6501 hardware
Hello,  i want to create one installer. In my code i am using one usb-6501 hardware and my code size is not more than 60 mb. i have created installer by selecting DQA with option full. But this the size of the installer is going up to 720 mb. i tried for option runtime 3 and runtime 4 option to reduce the size of installer.but tith same installer os not working properly. so, Except this is there any other good solution which will make installer small in size and works properly?
(2,345 Views)
I have had success with the runtime 4 option. If it does not work for you, you need to explain exactly why it does not work.
When I used option 4, I also included MAX and exported my hardware config. Did you do this?
(2,329 Views)
