how do i pass a daqmx task from labview to matlab using the math interface toolkit?
I want to use DAQMX functions from Matlab using the Math Interface Toolkit (MIT). How can I have a labview function output (return) the DAQMX task to matlab via the MIT?
I want to do this so I can start a DAQMX task in Labview from a matlab function and return control to matlab without losing the task.
(2,770 Views)
Hi Mark,
(I already posted this answer in your other thread, but let's keep THIS thread alive - it makes more sense here in the LabVIEW forum than in Instrument Control forum.)
Since the DAQmx Task is not a native data type that can be passed directly to MATLAB from LAbVIEW, try flattening the DAQmx Task to a string before passing to MATLAB. However, I doubt that you can access the task from within MATLAB, but feel free to give it a try.
Good luck!
- Philip Courtois, Thinkbot Solutions
Thinkbot Solutions
(2,761 Views)
For further replies, please refer to this other thread in the LabVIEW forum, thanks.
Thinkbot Solutions
(2,760 Views)
