how do i pause and reset timer
i want to pause and reset this timer . can anyone help me please
thanks in advance )
(3,392 Views)
Hi akshay,
Then you need to implement those features in your algorithm!
- You need two buttons, so the user can switch to a "pause" mode and "reset" the timer.
- Using shift registers you can store values to be used in a loop for later iterations.
- I envision a simple state machine approach to solve your problem…
(3,369 Views)
i have the buttons added
Do i need to use case or an event structure?
(3,351 Views)
Hi akshay,
whatever suits your algorithm.
You can use both of them…
(3,348 Views)
