how do i post my vi on to the message forum for review
I would like to be able to post a small VI on the messages forum so some one can review it. I saw that it can be done but i dont know how. Its not the same as creating a snippet?
Please help
Alex
(3,118 Views)
A snippet is good, as even people without LV (maybe they use the private PC) or with a version lower than the one you use can review it. In addition you can also attatch the vi, so those that have the high enough LV version can download it and run it with the information missing in the snippet. To create snippets with LV versions below 2009, you can use the CCT (Code Capture Tool). If you attach your vi, do not forget to attach SubVIs taht are necessary for it (but they should be your own VI's and not part of e.g. a NI toolkit).
Felix
(3,107 Views)
Goto post message--->u can find add attachment at the bottom,there u can attach the vi and send
(3,106 Views)
Could some one please tell me how I make my numerical inputs down the left hand side reset to 0 when the while loop gets its stop signal?
Much Much appreciated
(3,103 Views)
PLEASE STICK TO ONE THREAD. How many threads are you going to start asking the same question?
Original thread
(3,084 Views)
