Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
how do i prevent the default 0(if for example) from passing forward?
cn_tower
Member
05-21-2004
11:39 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
how do i prevent the default 0(in the case structure for example) from passing forward? (i.e. don't wanna see 0s in my output files)
0
Kudos
Message
1
of 2
(2,381 Views)
Reply
Re: how do i prevent the default 0(if for example) from passing forward?
Enrique
Active Participant
05-21-2004
01:05 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
cn_tower;
You need to provide more information. Better if you can provide the code for review.
You can always delete a case from the case structure. Right-click on the case and select "Delete case".
Regards;
Enrique
www.vartortech.com
1
Kudo
Message
2
of 2
(2,381 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
