how do i save data coming to serial port automatically to a file when the vi is run at once?
i want to save data coming to my serial port
the data contains password operator name etc
which i want to save it to txt file only once
the data is changed
(2,978 Views)
You can use a while loop that check's the value of your serial port periodically, and write it to a file using "write characters to file" function every time it changes. To know if data changes, you can use a very useful set of vi's written by Brian Renken at http://brianrenken.com
Hope this helps.
(2,978 Views)
