how do i save the data in table ??? URGENT
Hope can attach some example VI for reference =]
Message 1 of 8
(3,642 Views)
If you're just trying to save the data to file you could use the Write to Spreadsheet File vi on the file functions pallete. You can wire your table data directly into this vi along with the path of the file to save to. Hope this is what you're looking for.
-rw
Message 2 of 8
(3,637 Views)
Write to Spreadsheet File.
Write to Text File
You seem to have a lot of dynamic data on your block diagram, along with a lot of conversions to/from dynamic data.
Message 3 of 8
(3,633 Views)
You didn't mention which version of LabVIEW you are using. I adapted your method in this example. Not sure this is an efficient method. I just pass the 2d array through in the false case.
Now Using LabVIEW 2019SP1 and TestStand 2019
Message 4 of 8
(3,599 Views)
oh sorry for tht !! my labview version is 8.6
Message 5 of 8
(3,564 Views)
Stay with one log in name ...please.
Message 6 of 8
(3,562 Views)
Soooo.... is your problem solved? You have not provided any feedback on the comments already made. If these do not solve your problem, then please provide more details as to what you are trying to do.
Message 7 of 8
(3,517 Views)
As was mentioned before, using the write to spreadsheet.vi will take the data that is being wired into the table and it will write it to a tab delimited file that can be saved in many different formats.  If this isn't what you are wanting to do, let us know.  Otherwise I will consider this thread closed.
Message 8 of 8
(3,457 Views)
