how do i small icon
When i create icon, LabVIEW let me create only 32*32 icons. How do i small icons such as icons of Boolean or Numeric vi's?
(3,877 Views)
The size of the icon can be made smaller if you remove the outer black lines and move them more to the center.
(3,877 Views)
I made that, but terminals remained on old places.
(3,877 Views)
The terminals have nothing to do with the size of the icon - they are defined by the connector pattern you use. If you want an icon about the same size as a numeric, select the pattern with 2 connectors on the left and 2 on the right. Assuming you have a single input and a single output, connect them to the uppermost left and uppermost right. Now, when you go into into the icon editor, select "show terminals". Draw a box the same size as the connector pattern you're wired to. Make sure you have the same icon for the b&w, 16, and 256 color.
(3,877 Views)
