how do i start acquiring data with an external trigger?
I am using an NI USB-6009 and am collecting pressure data from a transducer. I have a programme set up to take and save the data. I want to now be able to trigger to start collecting the data via an external trigger (switch). I am using the trigger to start another piece of software for a different sensor on another machine and I want the labview data to start collecting at the same time. I am unsure if the trigger section on the Daq assistant would be the right thing to use or if there is a better way to do this. I am very new to labview and have had help to get this far!
Thanks in advance!
Zoe
(3,323 Views)
Look at some of the examples of external hardware triggering, this is usually the way to synchronise multiple measurments
(3,310 Views)
Hi Zoe,
My name is Lanxi and I am an Application Engineer from NIUK. I will assist you with your query.
There are some rules you need to keep in mind when doing the multiple device synchronization:
1.All devices share a Master Timebase and a Start Trigger
2.All devices share a Sample Clock
3.Create one master task
-Configure master task, but do not start immediately
-Only start master task after all slave tasks have started
4.Create as many slave tasks as necessary
-Start slave tasks before starting master task
5.Data Transfer Bus cannot pass timing and synchronization signals. If sharing internal signals between devices, must setup a synchronization bus
6.USB Devices have no synchronization bus
-Must synchronize USB devices with external sample clock
Below is an example of synchronize measurements on multiple USB Devices which I suppose will be useful to you:
“Synchronize Analog Input on Multiple USB Devices”:
https://decibel.ni.com/content/docs/DOC-3864
Please let me know if you find this information useful and if there is anything else I can do then let me know.
Lanxi
(3,284 Views)
